Brights pop fuse
Bloodhound1981
MA
Rusty
C-10
No, you don't have it figured out, and NO they're not working right.. Go back, read, and study my first post and the post made by Ricko1966.. I'll say this one more time.. IF you have the headlights on any fuse at all, regardless if it blows or not, you have wired them wrong.. If the harness is an aftermarket item, it's MADE WRONG.. If you created the harness yourself or modified the original harness, it's done WRONG..
And speaking of done -- I'm done with this thread...
@Ricko1966 @RustyPile You guys are getting awfully worked up for a guy who already solved his problem. He's got a Painless harness, did Painless build all their harnesses wrong?
If that's how they made it,then yes they are made wrong,read the article I posted,it's a safety issue. Manufacturers did it to save lives, headlights used to be fused in the 50's and they figured out it was dangerous. The way his is set up if he has any problem in the lighting circuit at 85mph he is driving in total darkness. Set up properly he'd still have lights. I have worked on European stuff that had 5 fuses for lights, 1 for tail and instruments, 1 for each high beam,1 for each low beam. That way a short in the instrument cluster or taillights doesn't leave you driving in darkness. A short in one head light,or marker light,doesn't leave you driving in darkness.Just for fun go out on a dark road tonight,when your going about 60 mph,turn off your lights,try to stop your car and get it off the road safely.
RustyPile
Left on own accord
Elkhart, TX
Nick
1983 GMC
350 SBC
Why do I keep being dragged back into these senseless debates.. Rick pretty much covered the hazards of having the headlights controlled by a fuse..
You bet I get "worked up" when lives (particularly when it could be mine) are at stake. @bloodhound, I'm telling you this to your face.. The OP definitely has NOT solved his problem. The only thing he has done is figured out the cause of the blown fuse.. That fuse should not be there in the first place. HELL YES, if painless did indeed build their harness that way, they definitely did it wrong.. If a Painless representative should chime in on this thread, I'd say the same thing to HIS face.. People, it's a safety issue, not to be taken lightly.:banghead:
Dleslie212
Phoenix
Dustin
5.7L 350
I was just trying to get some help with a fuse
  • portrait-puzzled-unaware-attractive-bearded-man-shrugging-with-hands-spread-sideways-dont-know...jpg
RustyPile
Left on own accord
Elkhart, TX
Nick
1983 GMC
350 SBC
Listen Dieslie212, none of this argument is of your doing.. It's obvious you bought that harness in good faith.. Now you have statements from two individuals who just happen to be experts in their field. Both have stated fuses have no place in the headlight circuit.
This may not be the help you were wanting, but here's the help you NEED.. Get rid of that poorly designed harness and demand a refund from whomever you bought it from. Your truck is safer in your shop without that dangerous wiring than it would be taking you into oblivion with it installed.
SquareRoot
My headlights are fused. No issues.
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
Looking for understanding, but look at this
Do modern cars then have multiple fuses for headlights?
I had an 05 mazda 3 hatchback once. Headlights blew out. Fix was new bulbs and new sockets.
Now I'm going to have dig into my shop manual for the truck and see what it says there.
Not discounting the safety points made already.
Factory wiring for Chevy truck like 1975-85 I've attached a pic,look at what the red wire does. Go look at a factory 73-86 Chevy pickup fuse box. No headlight fuse. I don't care how you wire it,it's your truck mine I'd want it wired like GM designed it which is as simple as just rerouting the 1 battery lead that is headlights only. Then the factory circuit breaker in the factory switch will do its job as intended. I put a link to a website that describes how the factory circuit is supposed to work,anyone who hasn't read it yet,probably should. It would clear up a lot of confusion. I just linked it again.
RustyPile
Left on own accord
Elkhart, TX
Nick
1983 GMC
350 SBC
Rick, you're wasting your time.. You can't see what's going on here???? Here, I'll help you.. Some people just like to argue.. And usually they're the ones that know the least about the subject being discussed..
CountKrunk
SW VA
Count
v8 350
Sorry @Ricko1966 forgot you posted a link on the first page. Read up on that, makes total sense. Thank you
I think a lot of newer stuff is relying on DRLs and independently fused high beams as backup. As long as there's a redundant circuit so no one's driving in total darkness. I'd even be tempted to put a 20 amp circuit breaker where Painless is using a 30 amp fuse. There's a reason for dropping the amperage. Look on line even some of the cheaper universal headlamp switches come breaker protected,so the lights pulse instead of die in a short circuit situation
This popped up tonight on another thread. Kinda funny because I was thinking about this exact thread yesterday. ( mowing,way to much time to think about stupid sh*t) Anyway was just thinking about how this harness went retro decades on the headlight circuit,but no one would consider down grading their brakes to 1960 standards. Someone posted his fuse section from his 81 owners manual,so you can see this is how it was designed factory. IDC I just want anyone considering using this companies harness to know they should consider an alternate lighting circuit. Easy to do it's just 1 more wire and a factory switch. You are not supposed to be able to pop a fuse and lose your headlights. Taillights NBD headlights fairly dangerous.
Doppleganger
OH-MI: Just like it sounds
Did the Painless setup involve relays at all? Thats how mine are going in regardless.
6Liter C10
