Back to intermittent wipers..
R8rPhan
California
Mark
1973 (1979?)
C10 long bed (Frankenstein truck)
Id seriously like a tilt column.. but at the same time, I have a manual and the steering wheel has no clearance issues. And wiring is all good, with the only three electrical components on the column I interact with being the ignition, turn signals, and horn(inop). However, I cant remove the key. So maybe I need to consider. Meh.
My horn is inop too.. I rebuilt the innards as far as the turn signal, the horn and all that, I'm just missing the spring and the button... There are times I need it... I should at least rig something up for temp.. but you know.. lol
EastAustinSawdust
Austin, TX
Adam
C10 Big Ten Bonanza
5.7L 350
Following up here. I purchased a refurbished intermittent wiper module + new intermittent wiper switch from [mention]gmachinz [/mention]and finally installed em today. Took 15 minutes to go from 2 speed wipers to intermittent. Plug and play. Very worth it. Thanks [mention]gmachinz [/mention]! Pics below.
Original 2 speed switch:
Original switch plugged into harness:
New switch (upside down):
New switch has receptacles for 2 harnesses (both go to the intermittent module):
Intermittent wiper module. I assume it’s some sort of relay.
Module plugs into the OEM harness at one end and the switch at the other.
And that’s it.
And that’s it.
my take away from this whole walkthrough is your dash cluster has a CLOCK.
gmachinz
Harnessworx Inc
Iowa
Jabin
Awesome! Happy it all worked out! Those modules are getting very hard to come by too!
