Auxiliary Battery Tray
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
Ok. It's a tight fit once the ac compressor is installed too.
This is what I decided to do, I left the long leg like it was, drilled a 1/4" hole just above it, used an existing hole where the jack would be mounted. I'll use that mounting hole on the long leg as a place to tether the MAF sensor wire.
RoryH19
Rory
R10 Silverado SWB
Looks good. You may not have to heat your leg since the 70s inner fender is a little different than the 80s.
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
I know this post has wandered from the battery tray, but I'll still buy one if I can find it.
page 1
ESONE
