Auxiliary Battery Tray
for potential ideas for people, I BELIEVE this is the factory tray for a prev gen gm truck to 72, correct me if IM wrong, but it was bolted into my square by my grandpa
ignore the battery that was more for the size comparison and he bungeee mess for a photo lol.
this isBelieve is a normal tray for a 73-80
RoryH19
Rory
R10 Silverado SWB
do you have any means to protect it from ESD?I would find one of those slim profile plastic holders that encases it with a air flow path so that its got a physical barrier, just in case
Good point. I've had it like that for 2yrs now but added protection would be a plus.
custodian
Catawba
William
5.3 LS, 350
My donor came with the same fuse box as yours. I rewired mine and removed as much as possible. Also fabd a bracket to hold my computer.
I used the original computer holding bracket (the plastic part), trimmed off the back side and mounted it to the fender well.
RoryH19
Rory
R10 Silverado SWB
I sure that was faster than my method.
RoryH19
Rory
R10 Silverado SWB
Looks like the same one for my 78
i only state that from personal experience with a similar Delphi PCM
pretty close in design and it didnt seem to suffer but i had alternator wiring to it incorrectly hooked(PCM monitored PWM of AD alternator, can command on, off, but cannot dictate duty cycle, only monitor it, the newer ones do that tho)
and i saw a spark from case to fender and was like :O
custodian
Catawba
William
5.3 LS, 350
Right, the 73-80 parts are harder to find.
Here's what mine looks like installed.
What brand is the cold air intake, part number?
RoryH19
Rory
R10 Silverado SWB
It was from ebay. I just bought it for the car I pulled the engine from. I then added a support brace from the inner fender to the tube. I didn't waste money on a k&n or airaid since I wouldn't need the air box around the filter that sits on the fender.
custodian
Catawba
William
5.3 LS, 350
K. I found one that looked similar on Ebay for a Silverado. Also, how did you mount the coolant tank, I received mine today.
custodian
Catawba
William
5.3 LS, 350
Never mind, as soon as I lifted the hood I knew where to mount it.
RoryH19
Rory
R10 Silverado SWB
It is also from the donor. I mounted it on the fender similar to how the original one was. Carriage type bolts through the fender. I had to heat the legs a little to change the angle to follow the curve of the fender.
RoryH19
Rory
R10 Silverado SWB
Ok. It's a tight fit once the ac compressor is installed too.
custodian
Catawba
William
5.3 LS, 350
I can always move it if I have too. I'll be heating up the longer leg to get it to mold to the fender.
brentjo
