Another. What rear end is this?
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
On the 76 Sprint. One I'm building a roundy round car. Cannot find a match for the cover shape, closest I've seen is a BOP? Nor have I been able to locate any numbers, so far. Have a line on a 9 inch Ford, but would run this one if I can figure it out.
Appreciate it Guys!!
Shakey
It looks like the oddball axle in my wagon, but mine has a fill plug on the cover. It's actually a 12 bolt axle, but the cover only has 10 bolts. Almost no parts are shared with a 12 bolt. None of the 10 bolt stuff works either.
In that year it should be either a 7.5" 10 bolt or a 12 bolt. Looks like a chitty 7.5" 10 bolt to me.
Definitely not the 7.5"
Upon further research, when the rear axle is searched on Car-Part.com for a '76 Sprint, all the listings are '76 and '77 units. Which goes right in line with other tidbits I dug up. The earlier years, like my '73 have 31 spline shafts. The last couple of years were downgraded to 28 spline axles for some reason.
It's a very obscure axle and finding numericly high ratios and posi units for them is like finding hen's teeth. A common 8.5" 10 bolt from from a '77-'96 B-body (think Impala SS or 9C1 police car) is basically a bolt-in type deal.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Good info @bucket ! It is appreciated! Looks like I will be "adapting" the 9 inch Ford up under there. My understanding is the gear sets and disk brake units are readily avalible and not to expensive for them. Plus it is from a pickup and 4 inches wider. Need an extra for your wagon, more than likely be one in Texas come January.
my guess is based on the obscure, hard to find, not exceptional, mundane ness of it, prob not . but we all have issues not accepting or doing our part to curate history sometimes. thats what its called. curating history. sounds nicer than the alternative lol
We can go round and round on what it "might" be. It has the square case lugs on the bottom of the pumpkin like an 8.5".. but the easiest way would be to wire wheel the crud off the top of the passenger side axle tube and read the stamped numbers on there. The first three letters in the stamping will give you axle type, original ratio, and original application. The rest of the numbers will give you date of manufacture.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
There are no numbers on the axle tubes, either side. Nor on the tops of the "gussetts" on the pumpkin. Will get it jacked up and look futher at a later date. Did earlier when it was up in the air but just scratched around with my knife, couldn't find anything to investigate farther? I slam have no idea??
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
You accusing me of butchering a classic? .... i am, but ain't, just making it into what the old car wants to be.
seanhatesregister
