Swims350
- Jul 30, 2010
- Logan WV
- Chris
- K10
- none
yep I use the car or truck to break em down, I never steer, I just use the back tire, run it over, turn the tire, run it over, repeat until it comes loose. Then they pry on and off fairly easy. I usually walk them back on, me on top or my knees walking them onto the rim, then I do just as said slam on the back bead and pull to the front and shoot the air to em. The best and fastest way is to remove the valve core, sock the air to the empty valve and try to make it seal up to get air in the tire, once it does it'll pop, pop then you're done, remove the air chuck, stick the valve core in and air to spec. My old man taught me that trick a few years ago.
