SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- C20
This is what I would do on my vehicle or a customer at the shop. If the bracket is bent replace it as that could affect belt alignment. As long as whatever is through the alternator and the bracket gets tight and holds in place that will work, a nut can be a pain but it will do the job. The alternator is suppose to be threaded, on my own vehicle I'd probably pull the alternator off and install a helicoil in it, but at the shop we'd give the customer the option of a nut, or replacing the alternator and the labor to R&R it and install a helicoil would likely cost more than replacing the alternator, so it might be on your truck. The way it is because it was what someone could afford to do.
Om another note are you running a fuewl pressure regulator with the edlebrock?
