Ac Delco ignition module not compatable wIth duralast distributor?
Hugomartin
Banned
Nc
Hugo
V20 3/4 ton 5.7 350 suburban
Maybe my “pick up coil” is bad. I just tried to put back in the old duralast ignition module but I cannot get the engine to start with that either.
Should I try trouble shooting the spark plugs with new ones first since it’s probably easiest ?
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Check for spark, also Have someone crank it and watch for injector pulse. If there is no pulse it's probably the pickup coil.
Hugomartin
Banned
Nc
Hugo
Tried cranking while watching the injectors and the do spray fuel when I’m trying to crank it
squaredeal91
Greg bush
1991 SB
So i would look for spark now. Take note of spark color if there is a spark.
Hugomartin
Banned
Nc
Hugo
Whereabouts do I look for spark?
For clarity this is the number one spark plug correct? It goes to the first place on right on the engine closet to the fan on second pic
Hugomartin
Banned
Nc
Hugo
This seems like a good video to check for spark
Hugomartin
Banned
Nc
Hugo
Yes i got spark looked orange to yellow in color.
squaredeal91
Greg bush
1991 SB
Super weak. Should be blue. I think its a bad coil.
Hugomartin
Banned
Nc
Hugo
Is there any other tests?
Will I be able to service a bad pickup coil and not have to remove the distributor?
Or do I need to remove the distributor?
squaredeal91
Greg bush
1991 SB
Please Excuse me. I meant ignition coil because of the weak spark. It's mounted on intake manifold and center plug wire goes to distributor.
SquareRoot
Why do you assume the issue is with the distributor? TBI can have it's share of issues elsewhere as can a failing fuel pump. Both of those can cause the same symptoms you're describing. Outside of loose connections, an electronic component either works all the time or fails completely.
Hugomartin
Banned
Nc
Hugo
Maybe I just need a new cap I had a new one lying around
nbrizjr
