89S 350 TBI Head Gasket Replacement Project
Did you go with a 180 degree tstat?
It's a *195. Of course today my mechanic told me today I should take it out and put in a *160.
:rolleyes:
:hmm:
If I'm, not mistaken, that EGR vavle looks stuck open to me. Usually the pintle will be below the mouting surface 1/4 inch or so, not flush or recessed like it is. Or is that just what I see in the pic?
He says that that GM made the heads those years thinner walled on purpose to hold more coolant and to run a hotter thermostat to get better on the sniffer. And in doing so you have the common head cracking issue on these motors. So I am going with a thicker walled, aftermarket replacement head and a cooler thermostat.
:handshake: sounds logical to me. I've just never heard of using a tstat as low as 160 before but I'm not a mechanic so that's not saying anything :lol:
I think it is just the style valve or make of it. I noticed that too when I compared it to the old one, the old one was hanging down further, but the actual valve mechanisms looked different from each other, I should have taken comparison pics.
:rolleyes:
You need to fire your mechanic cuz he don't know his ass. You don't run a 160 or a 180. You run a 195 so you can get the computer into closed loop mode at 187-192 degrees.
Really? :think:
yes, the computer will run the motor rich all the time, and keep the timing retarded thinking the motor has not reached operatiing temp yet. Hurts performance and mpg.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
Maybe he was thinking pre-TBI squares?? Just a thought........:shrug:
Could be, I can see how it would affect the computer, but if I put HD heads on it it shouldn't be a problem to run the *195 t stat I would think. :hmm:
burnt
