89 3/4 Ton conversion consideration
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
I'm just wondering, what are you doing with your burb that makes you need 3/4T suspension? The reason I ask is because it's not easy to physically carry enough in a Suburban to need the extra capacity beyond a 1/2T. If you're towing, well, that's a different direction looking at brakes, transmission, cooling, and gears. If you actually carry a lot in the burb, you could put on some overload airbags and be done with it. Brakes can be upgraded without swapping axles, so I'm just wondering if this is more of a conversion you want to do just because you have the parts or what?. Not trying to talk you into or out of anything, inquiring minds just wanna know what's your motivation?
idahovette
Weiser Idaho
Perry
K20-K10
See post # !
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
Hahahhhahaa....
Damn skippy pal.
My delicate physique would not handle all the humidity in the South.
The PNW is the best place to be in the USA.
It is damn humid. Over 90% most days.
My snowflake conservative feelings wouldn’t allow me to live near that many liberals. You are a better man than me. Lol
idahovette
Weiser Idaho
Perry
K20-K10
Iirc and I think there was a post on here about it. Its the same issue as the pickups. Being the single sheer point for the upper mounts. They tend to flex or something which causes the frame to end up cracking. But, and this is going off memory so I could be wrong. The burbs upper mounts are harder to fix because they are closer to the body, or something like that. Fabbing up a double sheer bracket for those positions might be enough.
ORD sells double sheer brackets but only for the pickups for some reason.
https://www.offroaddesign.com/rear-...87-91-k5-blazer-jimmy-k10-and-k20-pickup.html
Vince @TubeTruck had built a bracket for the rear shock mount that looks pretty good. It's in the thread Restomod 4x4 Suburban?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Vbb199
Salisbury NC
Vince
Vbb199
Salisbury NC
Vince
You know it is bad JUJU to say **** like that! Lol
You know I gotta *** with you about the caravan!!!
Vbb199
Salisbury NC
Vince
I swear, every post I make everyone jumps on board and starts **** talking lol.
Love you guys.
Vbb199
Salisbury NC
Vince
There is something I didn't think about, but a friend pointed out, I won't be able to run a 15" wheel anymore with the conversion, will I?
nobreaks254
