87 R10 truck dash harness needed!
circuitguy
Elk Grove, CA
BIG-C
GMC 1/2 ton Stepside
I am going threw all each electrical harness and found that the dash harness has burned wires and need a bunch of work. Anyone out there have a good used dash harness from a 87 Chevy full size truck or 87 to 91 suburban or blazer? I think these are all the same when it comes to the dash harness. Any help would be great!
f6john
I was at the pick-a-part today looking for an instrument cluster and they had a Sub but the cluster was gone. As I recall the wiring was still there. Not sure how much work it would be to remove as I've never tried for a dash harness.
circuitguy
Elk Grove, CA
BIG-C
If its a 87 to 91 suburban then it will work. needs to be undamaged, no burned wires.
I would hit the wrecking years too but I have a bad right foot and cant walk or stand too long.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
90 and 91 had electronic speedos, iirc.
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
Should be 1987-1989 k5, suburban, r and v series. How much of a harness you need, just under the dash part?
circuitguy
Elk Grove, CA
BIG-C
I need the complete interior dash harness. Mine is burned real bad. Just need to make sure it will fit my 87 with TBI.
cobra20
Portland, Oregon
Hans
V1500 Suburban, K5 Blazer
5.7L
still need the harness?
circuitguy
Elk Grove, CA
BIG-C
Yes, still need one.
cobra20
Portland, Oregon
Hans
5.7L
well I'm hitting a pick an pull on Sunday I'll see what I can find
circuitguy
Elk Grove, CA
BIG-C
Cool!! Let me know what you find.
cobra20
Portland, Oregon
Hans
5.7L
ok I got most of it apart. I need to go back later this week and finish pulling it out, do you need it where the wires attach to the ac system? Also here is the vin of the truck it is coming out of 1gngv26k6kf139366
circuitguy
Elk Grove, CA
BIG-C
Looks like you have a 1989 Suburban with a 5.7L with TBI fuel injection.
If its a good uncut and undamaged harness its should be the correct one. I do need the complete interior dash harness with all the plugs intact but I do not need the interior AC harness it plugs into, you can leave that one there.
PM me your number so I can call you to go over this. I could use some other parts from this Suburban.. want to talk about that too. Thanks a bunch for your help!!
circuitguy
Elk Grove, CA
BIG-C
Here is a pic of one out of a 1987 Chevy Truck without AC. This is what I need.
zieg85
Brighton, IL
Carl
7.4L
I have a complete one out of a 1991 R-2500 Suburban if anyone has a need
circuitguy
Elk Grove, CA
BIG-C
I think 91 has an electric speedo, wont work for my 87.
awchevy
