86 on 91 frame
tetford79
canada
Jeff
I had an 86 c10 for a while now with a decent body but the chassis is shot. I just recently came in to posession of a 91 k10 350 5 speed single cab long bed with a rusted out cab. I am thinking about putting the 86 cab on the 91 frame.. but I can't find much info anywhere on it. Does anyone know if any of the cab mounts will line up, if I'll need a body lift, steering column etc etc.. any input is appreciated.
I always was a member here but I haven't been on in so long I forgot my username so I just created a new account.
yevgenievich
Place
Name
Year
Model
Size
The frames are different width. It could work, but nothing would line up
tetford79
canada
Jeff
Assuming the 88+ style are wider? That would be tricky. Moving the mounts either inside the frame out farther out on the cab. Possible still though.
hatzie
k20
The T400 frame is setup for a fair sized fuel tank inside the frame rails. This makes the GMT400 frame rails wider apart and much closer to the inner cab rockers VS the squares that have enough room for a long narrow fuel tank between the frame and the inner rockers.
You might be able to do it with enough patience and skill. There's a gent that put a stretched 50's or 60's IH pickup cab and bed on a GMT400 Pickup Chassis.
tetford79
canada
Jeff
Ok, good to know. I'll give it a shot anyway and keep you all posted how it goes.
zapattack
