Doppleganger
- May 24, 2019
- OH-MI: Just like it sounds
- Chris
- K20
The following pics and descriptions only apply (to my knowledge) to 85-91 SB wiper motors. I started with 3 motors and chose the worst one to rebuild. With it on a bench and no transmission connected, it ran at about 20% slow and a tad more more on hi. Keep in mind these are motors that are close to 40yrs old that came on trucks with 12 month warranties. I dont think these were ever meant to be serviced, which made the end result of this even better. Hopefully this is of some help to someone. This is an extreme overhaul, one I doubt most would ever need to do. Enjoy.
1-2. Overview
3. Drill out the 10 shell rivets. The steel is very thin so you dont want to remove anymore than you have to. 19/64 is a perfect size, 5/16 works too. Then gently use a small flat screwdriver to pry it apart.
4. The dirty secrets. You can see on the top half, the rib on the gear going from 9 to 1:00. Thats what triggers the parking switch. On the bottom half, the 2 magnets are kept in place by 2 spacers - one on top and one underneath. The one on top was ajar and allowed one of the magnets to attach itself to the armature, effectively sandbagging it from moving.
5. The gear shaft is held in with 4 washers and a snap ring. I used the .040 pins in my snap ring pliers to remove it. Careful not to tweak it - although its easy to bend back if you do. The shaft rides in a pressed in bronze bushing. You dont want to mess the bushing up. Its a tight fit so any burrs, shavings, dirt, etc and it isn't coming out. Use a scotch brite and twist it like you're polishing a bullet. A tap from a rubber handle or dead blow and it will then come out no problem.
1-2. Overview
