atxb
- Jul 7, 2024
- Austin, Tx
- Brandon
- K15
Evening! I’m working with my dad and brother on fixing up his K15. Some time in the past, my brother tried rebuilding it, and it simply wasn’t put back together correctly, so knowing parts are missing, I’m just wanting to replace the whole thing. No salvage yards around here have had a replacement, so now I’m looking online. I struggle with the $800+ options because this isn’t a full on restoration. I see these universal ones, but I lack the knowledge to know what may be needed to make it work in this truck.
So when looking at something like the below, what do I need to consider as potential “modifications” to make this work?
www.speedwaymotors.com
Universal Keyed GM Tilt Steering Column With Shifter, 32" Black
2-inch OD column housing, accepts any 2-inch column mount or drop Overall length from end of bell to tip of steering shaft is 32-inches Five position tilt mechanism with 30 degrees of total adjustment Includes ignition switch and keys Integrated GM style self-canceling turn signal switch with...
