'73 Chevelle SS Wagon (local find)
fast 99
Spokane, Washington
That's about 2 hours away, tempting.
Purchased a 74 Elcamino for parts. Got it home and decided to drive it for the summer. Optioned with PW PS PB PDL 454 AC everything but an SS. Like it so much fixed the rust and painted it. Owned it for 10 years but had to sell for financial reasons. Even though it was a low HP 454 was hard to keep rear tires on it. Was a fun pickup, miss it.
Those S3 Lagunas were heavy, tried to pick up one end of a front bumper laying in a field, couldn't do it. Had to weight about as much as a small block.
Oh yeah, I've picked up one of those Laguna front ends before. It's unbelievable how heavy they are. I think only those that have tried to lift one will understand, lol.
fast 99
Spokane, Washington
Had a buddy named Chuck with a 77 Elco/ Laguna nose. 6 inch rod 350 with Dynomax race bullets, f-slow.
Had a friend with a 350 powered G body 78 up Elcamino. I raced him once with the 74 elcamino, it was very close. Actually, looked into installing a 454 in the later Elcamino. Only real issue was heater box interference and there was an aftermarket one available. Just never did it.
REVINKEVIN
Sugar Land Texas
Kevin
Hey. I read through most of this post. I can attest that the stock Laguna noses are very heavy. I think the one on my car was over 150lbs. I swapped it out for a fiberglass nose. I know some people on another site that know all about the 73-77 GM cars. My friend has about 10 of them. Here’s a picture of my “76 S3. It has a 496BBC, TREMEC 6-speed, and a bunch of other things. Cheers.
REVINKEVIN
Sugar Land Texas
Kevin
Oh, thanks for the likes. Here’s some big block inspiration if you like. Here’s a link to some very knowledgeable folks about this generation of cars. I know that at least one guy has a car like yours. Cheers.
For those folks that aren't aware, G3GM.com is much like here, but the focus is 70's GM midsized cars obviously.
Long time, no update. Mostly because literally nothing has happened recently. Like, at all. I think it was last fall maybe, I changed the trans fluid and filter, only to discover that the servo seal was leaking. The leak has since slowed, but I still need to fix it. All I've been doing is firing it up from time to time, whenever I need to open up that spot in the garage. The car has been popping and banging and running rich.
So that brings us to today. I wanted to install the dual point Accel dizzy that @Rusty Nail had sent me. Unfortunately... I don't know where it is, lol. I'm pretty sure it's still packed in a box somewhere, probably in the house. I had it in the house at the old place, and I don't remember putting it with the garage stuff at the new place. So as a temporary solution, I went through my tub of HEI stuff and put together a relatively new-ish HEI setup for the car. Including an old set of 8.8 wires that I think may have been on my '88 Burb 10+ years ago. Only one boot needed replaced.
@Rusty Nail here's the electronic Accel dizzy I can finally send you now. The car runs much better now, but I don't think the dizzy had anything to do with it. The plug wires were garbage.
I'm still setting timing with the 70's light that my dad gave me.
Still keep it in the box too.
The tag says it was 39 bucks I think.
The car does still have an off idle stumble/hesitation. Certainly seems like the accelerator pump is to blame. However it is also very prevalent at road speed, so it may be the carb itself. Maybe I'll go though it again.
pr1978
