- Apr 11, 2017
- kansas
- Rick
- c20
All you have to do is break 12v source to transmission. IDK why you wouldnt just use factory pieces and put it back as factory, you can interupt 12 power with a standard parts store relay. Wire it so relay is normally closed. 12 v from brakelight switch opens the relay, interrupting 12v to transmission. Ill try to find you a relay number and write a schematic for you. Okay looks like ry116 would be a good candidate. Run 12v supply to the transmission through 30 and 87a, ground 86 and supply power to 85 from the brakelight switch. Now when you step on the brakes the 12v source from the brake light switch will open 30-87a interupting power to transmission.Making sure I'm not overlooking something obvious-
My TCC brake switch is starting to fail. Currently it is hooked to the cruise control vacuum brake switch. (I don't have cruise control anymore) I know the circuit must be opened when brake is pressed (opposite of brake lights). Wouldn't a 4 terminal brake light(cruise control) switch work? Or is there another switch that is preferred?
sorry the question might be slightly off topic-
