Austingulick
- Feb 26, 2018
- Oregon
- Austin
- K5
- 6.2 diesel
This is the motor
What do you mean by "built"? As in hi performance? If it's for sure a Turbo 400 and not a Th350, it don't need to be "built". It just needs a stock rebuild. A couple little holes drilled in the valve body spacer plate and lose a check ball or 2 and it'll firm up the shift a bit. I'd go with a Stage 1 RV type shift, not a neck snapping Stage 2 or it'll beat the hell out of your transfer case. They are plenty strong and will easily handle up to 500hp in a stock build. I just ordered a rebuild kit for one of my Turbo 400's. Chances are my steels are fine so I'm not replacing them, I have common bushings if even needed already. This is also a Waffle Clutch pack kit. The waffles allow better cooling. I added new bands which I may or may not need but will replace anyway, and a new good brass filter. All less than $100 and it'll be deleivered to my front door by Friday. Nut up a bit and find a buddy that has a bit of experience and build it with him yourself.I will probably just bolt it up to the one I have and save my money to buy a built turbo 400
That wasn't a boat engine?This is the motor
It is on 35x12.5s. And is there kits for a serpintine belt? Don’t they just make brackets for the alternator and pump? Maybe the diesel ones will fit?I ended up doing something similar with my 86 C20 after the diesel died. I used a built up 350, kept the hydroboost setup, and the TH400 with a different torque converter, and had it reworked by a trans shop to work with the gas engine better (think they only changed out the governor and some small things)
Like Hotrod said finding the brackets will be a huge PITA, I ended up making one for my power steering pump, was never able to get it lined up correctly. Would be easier but more expensive to just get a serpentine belt setup.
The gearing may be high for stock sized tires.
If it has the huge diesel radiator that is also a big plus and something to keep, even though it will take a long time for all that water to heat up so the thermostat on the motor opens without just slamming shut a few seconds later. Also finding an upper radiator hose with the correct bend is kinda tough.
