6.2 diesel to 396 swap.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
So now I’m confused, when I swap it I have to buy a brake booster for a gas, correct? What about power steering.
No keep what’s there brake wise. You will need to get a hydraboost ps pump for a bigblock. It will have dual returns. One for the brake assist unit and one for the steering. If you look at what’s on yours now you will see what I mean. You may just need to get big block brackets.
echo7bravo
Alabama
Adam
K-10 stepside
350/Th400, 4.56 with 35" BFG MT
No you don't have too. You just have an option that did not come on gas models. Whether you keep it or swap to the booster means nothing other than preference.
I have a couple. :D
A$$
Austingulick
Austin
6.2 diesel
What about hooking up to the transfer case????
echo7bravo
Alabama
Adam
K-10 stepside
If your swapping in HB make sure you have the HB pedal you’ll need it, it’s different then vacuum assist pedal.
I thought the only difference was the rod coming through the firewall.
echo7bravo
Alabama
Adam
K-10 stepside
Transfer case on a powerglide?????? uh..... I dunno
Do they even make a short tail housing for the powerglide?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Nope the pedal itself is different height wise. I thought I had a side by side pic. In my build thread I do I believe
echo7bravo
Alabama
Adam
K-10 stepside
Hmmmm Something else to think about if I keep my booster versus the hydra boost.
This Austin fella is wanting to marry up a drag tranny to a transfercase. If at all even possible, what would the torque be like on the stock gearing. Wheelies in the parking lot on 33s? LOL
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I guess I missed the 4x part. Get the 400 rebuilt and sell the glide. Unless you want to do a divorced transfer case and you probably don’t. The 400 is a perfect match for a big block.
Austingulick
Austin
6.2 diesel
What about the tranny mating up to the np208?
Austingulick
Austin
6.2 diesel
What about the tranny bolting up to the transfer case? It’s a np208
I'm not reading the whole thread, so If I'm reapeating something forgive me, but just to give my opinion on the first few posts I read...
Yes, keep the hydroboost since you have it. It is a stronger braking system for 1, and if you ever go with a big cam that lacks vacuum, then no worries, you still have all your brakes.
As far as the Powerglide, nawww, I'd skip it and just have the Th400 that's in the truck built. You sure it's a Th400 and not a Th350? Either way, it's cheap to have a Th400 or Th350 built. I can't imagine it's anywhere over $400 if you do the R&R (Remove and Replace) yourself. You'd probably spend close to that getting your driveshafts remade and balanced to fit the Powerglide, not to mention the adpater.
echo7bravo
Alabama
Adam
K-10 stepside
I’ve got a 700r4 connected to my np208 since I’m running 456 and 35s. Helps me get my gas mileage up to 4mpg.
Austingulick
Austin
6.2 diesel
I will probably just bolt it up to the one I have and save my money to buy a built turbo 400
Austingulick
Austin
6.2 diesel
And it has a huge cam btw
Austingulick
Austin
6.2 diesel
Okay so in conclusion I’m gonna mate it up to the current tranny. So I will need just a new tc. I’m gonna need motor mounts unless the 6.2 ones will work? The radiator will work correct? Is there anything else I will need?
patchy0990
