4mm vs 6mm back glass. What's best?
Bennyt
Surprise
Ben
73-76 back glass is 6mm and 77-91 is 4mm. Any benefit to using the 73-76 glass on my '90 CC. Quieter, stronger? Both are the same price and appear to use the same seal.
Turbo4whl
Downingtown, PA
Wayne
Thinner glass was for weight saving. Square trucks were designed when fuel was $.30 a gallon. Then the first fuel shortage and price hikes. Lots of items changed in the square years. More plastic too.
Bennyt
Surprise
Ben
...but is there any advantage? I'm adding 50 pounds of insulation to the interior so I doubt an extra pound or two of glass would kill my mpg
Scott91370
Burleson, Tx
Scott
Sierra1500
It may be slightly quieter with the 6mm. I'd go that route if available.
Bennyt
Surprise
Ben
Mild RV 454 w/ headers. But adding a small centrifugal blower for towing when I build a 502.
No noteworthy advantages or disadvantages, as stated above it's just because GM was trying to save every ounce they could in the '81-up trucks. They even use the same gasket.
GMCk2500Dalton
