4l80 mvb stuck in 2nd gear
Column shifter in "D" and toggle switches.
Cool !!! You did use toggle switches right? You didn't go through your house I hope and rob light switches out of your bedrooms like Hillbilly Bob did in that video. I cracked the hell up when I seen that mess. :gathering:
80goldenburb
LV,LV Raider Nation capital
Nico
Suburban C20
'68 cad 472
i spent a whopping..........$2.77 on those light switches (pictured) mounted on the cardboard box. No i did not feel like gettin zapped by removing switches from the house :Grenade::rofl:
yevgenievich
Place
Name
Year
Model
Size
After checking, it looks you can try going back to previous set up, but keep pressure control connected and see if it will let you use the shifter to shift without messing with the switches. Other would be using a floor shifter with micro switches. That way the shifter selects the right shift solenoids.
So you really did :grd:
das5439
