4 inch lift is coming along
kenn
detroit
ken
c10, k10
Weather finally got a bit better (50s) 4 inch tuff country springs are on . Raised steering arm installed, working on replacing dry rot brake lines , ball joints, shocks, and drag link . Hope to be on the road next week
77 K20
Montana
K20 5" lift
HT383 fuel injected
Looking good- but one thing I'd like to mention is look at your sway bar. See how it is at quite the angle downward to the axle? When you hit a bump the axle comes up and will try to compress that sway bar. That won't happen. So it hammers your sway bar bushings up on the frame and makes it ride rough.
A free solution is to remove it completely- a lot have done this and notice a great improvement in ride and not much different cornering.
Or others then run a sway bar disconnect. Even if you don't disconnect it it will allow it to pivot and makes for a smoother ride.
http://offroaddesign.com/catalog/swaybarkit.htm
kenn
detroit
ken
c10, k10
Thanks for the tip, going to try both ways and see how it aftects ride . Rode like a dump truck before lift (with unknown springs and blocks in front) hope this springs are a better ride.
dhenderz
Michigan
Dennis
Alternatively, drop your sway bar down at the pivot points. I installed the Ruff Country 4 inch lift as well. I went with the Rough Country drop brackets.
kenn
detroit
ken
c10, k10
Plan b lol sway bar moved down to new springs( no binding), anioxus to test drive the new lift kit
kenn
detroit
ken
c10, k10
Brake lines were to short with lift, inspection of lines came up with cracks in rubber. Ditched the brackets, and bought longer steel lines .
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Good call... you're going to love how it drives. Let us know it it drives and how you like it with the sway bar disconnected.
Westislander
Massachusetts
Gregg
Who did you get your extended brake lines through?
Craig 85
Nashville, TN
454/TH-400/NP205
I've run ORD's sway bar disconnects in my last 2 trucks. They make a huge difference in ride. It lets the sway bar and springs run in different arcs, just like most vehicles with sway bars.
SrMousse
Colorado
V1500
I think I'm gonna give a no swaybar setup a shot as well. I have the bushing sweet for it and have to remove it regardless, I may as well dive it without to give it a chance!
ben_swager
