3500 front disc noise over bumps, is there a kit to fix this???
charlesg
wisconsin
charles
k3500
Anyone know of a kit?
Thanks!
Craig 85
Nashville, TN
454/TH-400/NP205
When I assembled my brakes I use caliper grease to prevent squeals and chatter. Are the bearings good/tight?
Are the caliper slide bits in place? There must be something loose to cause the noise.
K201979
Winona, missouri
Hippie
350ci
Im guessing the little clips arent in there and the pads are rattling. If thats the case, you can buy the clips.
charlesg
wisconsin
charles
k3500
yes, bearings all good
K201979
Winona, missouri
Hippie
350ci
Yeah, little spring clips that hold the pad in the caliper. Mine were missing and rattled like crazy. Id say i found them in ebay. Ill see if i can find a link or picture.
K201979
Winona, missouri
Hippie
350ci
Disc brake pad retaining clip
K201979
Winona, missouri
Hippie
350ci
Not sure if itll be the same part number on your truck, but id say thats what you need.
charlesg
wisconsin
charles
k3500
Thank you, the pads are loose in the caliper and the caliper is loose in the spindle, do they make a thicker spring plate for the bottom?
Craig 85
Nashville, TN
454/TH-400/NP205
Do you have these clips installed on the ends of the pads?
charlesg
wisconsin
charles
k3500
That is the inner pad? I dont have any clips on the pads at all.
K201979
Winona, missouri
Hippie
350ci
If the caliper is loose too itll be either the pins(that hold the caliper on)or the bushings and rubber orings in the caliper being worn. Ive bought the pins but not the bushings/orings because ive always replaced the whole caliper, but im sure you can get them.
charlesg
wisconsin
charles
k3500
I found a place that sells over sized slide plates, going to try that and the clips for the pads, thank you for all the info!
K201979
Winona, missouri
Hippie
350ci
Np, good luck n let us know how it turns out.
78silverado
