3500 front disc noise over bumps, is there a kit to fix this???
If the caliper is loose too itll be either the pins(that hold the caliper on)or the bushings and rubber orings in the caliper being worn. Ive bought the pins but not the bushings/orings because ive always replaced the whole caliper, but im sure you can get them.
The 1-ton calipers don't use the pins/bushings/o-rings like the 10-20's do.
You can see in Craig's pictures, there's just the slide bracket, little retaining bolt and then some anti-rattle clips for the pads.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
@K201979 they look like this. Not mine though.
K201979
Winona, missouri
Hippie
350ci
Thanks for the clarifacation. I couldnt quite figure out what i was looking at in those pictures, but now i see. Learn something new every day....if i pay attention:crazy:. So i guess he needs clips and i dunno what else:33:
78silverado
