2003 g3500
And theeeennnnnn?
yevgenievich
Place
Name
Year
Model
Size
Actually currently it is likely to just be set up as a movable shop that can move forward only under it's own power. And maybe at some point of time a transmission rebuild.
yevgenievich
Place
Name
Year
Model
Size
250k miles on this thing, multiple missfires, o2 sensor error and reverse band is bad. Likely a longer pin will make it work again, but for the amount of time it takes might as well just replace the transmission. Motor is probably not too far behind the transmission, 35-40 psi cold oil pressure. Also quickly figured out why bumper was pushed in so much, PO reverted to same solution as us in order to back this thing up.
malanr
