Two owner flatbed
arborvitian
Virginia
Long-Winded Loser
C30
Great looking truck and you can haul just about anything you want
Now all I need to do is wait until I can afford something to haul. I'm pretty thoroughly tapped out after this crazy build. It's nice being done with it. It was all-consuming for the last three months. I've got more I want to do to it, but nothing is a rush. I need to get it lined up, I need to put a curve kit in the dizzy to try to get the mechanical advance up. It's currently only adding 16°, and that could explain my really poor fuel economy. Instead of doing an HEI conversion, I'm going to try a Pertronix II kit I picked up cheap for Black Friday.
77Dmax
vt
Joe
Did you figure the gear ratio when you had the cover off?
arborvitian
Virginia
Long-Winded Loser
C30
Nope, I did not think to do that. I did figure the gear ratio from the tire size, and what I'm turning at what speed (2950 @ 70 mph). With the ratios available for a 14-bolt Corporate axle, I figure I have to have 4.10 gears.
Interestingly, the ratios on this Muncie SM465 with 4.10 gears and this size tires match up very closely with my Jeep with 4.56 gears and 35" tires. Up to 4th gear, they are nearly identical. The Jeep has two more gears, and that's why the Jeep is hitting close to 18 mpg, while the old Chevy is stuck at 6.3 or so. I'm working on that. I'm hoping a recurve kit in the dizzy will get me closer to 10.
David King
Crestview Fl. 32539
C-10
A lot going on there! Welcome from the FL Panhandle!
86 C10 Shortbed
Ohio
Mark
5.3L
Welcome from Central Ohio.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Welcome from Missouri.
Fat 454
Australia
C20 Suburban
welcome and 11 out of 10 for the impressive photo load out on your intro post. Most common call out here is "post pics", however you've covered that in spades.
Great inspiration for the rest of us with the project "still sitting in the barn waiting on parts .. "
Dang, you really know how to make an entrance!
Howdy from Ohio!
Kristjan
