1994 S10 1Ton SAS
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Bolted done solid.
(during these times of this "crisis" ordering stuff isn't gonna be easy, so I just used the old bolts)
Steering angle won't be bad at all.
Unfortunately this project will now be put on hold because I lended my chainfall to someone, and they broke it will "just picking up an engine"
I have no means to continue further with the little bit of front end work that's to be done.
Vbb199
Salisbury NC
Vince
An update with this, I went to HF before NC is locked down, bought a 2 ton chainfall.
Got the truck lifted off of the axle, then notched the webbing to allow me to slide a u bolt up in there.
That's about all I got done today, but the front axle is bolted down solid and the old factory steering drag link has been removed. So, I can safely begin working on the crossover.
I ordered weld bungs yesterday off Amazon, in the meantime while I wait on those, tomorrow I will do brakes at all 4 corners. Hopefully this will all work out with the full size master cylinder I put on.
Vbb199
Salisbury NC
Vince
Also I welded some triangle gussets to the front spring hanger for additional strength.
78C10BigTen
pennsylvannia
C10 BIG TEN
That's finally done.
Next up is to paint it.
SERIOUSLY, im super jealous of your machine skill!! If i need a part made im definately gunna look your way man! Right on! :happy107:
Vbb199
Salisbury NC
Vince
Thanks man!! I like custom stuff
idahovette
Weiser Idaho
Perry
K20-K10
Hey Vince, did your buddy help pay for the chainfall? Didn't he break it?
Vbb199
Salisbury NC
Vince
Claims he's gonna buy my old one since it worked so well for lifting a motor
Catbox
Peter
C20 Silverado Camper Special
Always amazed at how gung-ho you are with projects.
I need to get some of that going on.
Vbb199
Salisbury NC
Vince
At this point, I just have to setup my brakes
(purge old fluid out and attach the new extended brake lines and hook up full size master cylinder)
Finish steering
(drag link is to be made, I have everything except bungs which will be here Thursday)
Get the right lut nuts to bolt up the 2" wheel spacers
Modify crossmember to allow front shaft to hook up
Have driveshafts lengthened
Put tubes in front tires
I think that's all that remains for this project. All the hard stuff is taken care of.
Vbb199
Salisbury NC
Vince
Drag link is done. I have steering now!
Unfortunately I can't steer now with the tires on the ground because the pump is out of fluid.
Somehow in my all knowing mind I thought 1 quart would satisfy a full power steering overhaul
(new pump, new lines, new box)
I have a video uploading.
Vbb199
Salisbury NC
Vince
I don't have fluid in the system, but it steers without weight at least lol
78C10BigTen
pennsylvannia
C10 BIG TEN
Pretty easy by the looks of it
zapattack
