1994 S10 1Ton SAS
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
New ps pump installed!
Vbb199
Salisbury NC
Vince
I should get a special award for managing to bend a pulley for ps.
Anyway, I had another one off a big block lying around, so I pressed it on... With heat of course
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
Y’all should see this guy’s work. He’s good and fast lol. Man, you should pull the 502 and 5 tons from the k5 and put them in the s10. Run 54” bloggers.
Vbb199
Salisbury NC
Vince
WE HAVE POWER STEERING AGAIN!!!!!!!!!
Unfortunately it looks like I'm gonna have to notch out more of the s10's original IFS cradle for the longer pitman arm to clear... But at least I have power steering again!
Vbb199
Salisbury NC
Vince
I appreciate that!!!!
Im confident the th400 will take it, but the poor s10's transfer case wont... Would have to step up to a drop box to take that much punishment
Vbb199
Salisbury NC
Vince
I guess tomorrow I'm gonna focus on finalizing steering.
I need to finish my steering arm, make some bungs for the heims I have
(I would order but this China virus **** will keep Barnes 4wd from shipping)
And then saw my DOM to length.
Vbb199
Salisbury NC
Vince
Pretty B rate steering arm, I'd say.
It's half done, still need to remove it from its shell and mill down the back of it and bore out a pocket, mill the arm at a 5-10 degree angle and drill holes.
Dmack
Central OR
Dave
Your standards are a bit higher than mine if that is B rate. Some of us consider a precision machining a steady hand on a 4 1\2" angle grinder. Keep. up the progress. Nice work.
Vbb199
Salisbury NC
Vince
Oh you better believe it's precision. Just not the company standard of precision.
The precision I make a living off of is +/-. 0003
The steering arm is +/-. 005 because I'm using calipers
But I do appreciate it!
Vbb199
Salisbury NC
Vince
Got rid of the excess stock on the back of the arm, then drilled the kingpin bushing and spring hole out.
Now finish milling that out.
Next up is the angled holes
Vbb199
Salisbury NC
Vince
After some assessment, I don't need a angle on the arm. Just flat drilled will be fine... I don't have a 20" lift... It'll be OK.
Vbb199
Salisbury NC
Vince
Didn't include this.
seanhatesregister
