VAL
- May 29, 2012
- TUCSON, ARIZONA
- VAL
- K10 SILVERADO
Well, I finally found a serpentine system I wanted for a long time now. I found a 1990 C1500 at the wrecker yard, and I pulled the serpentine setup off of it. I Got the whole thing with all the accessories for $150. The reason I went with the 1990, is because it has provision for the smog pump, which I have to have in my 86 to pass emissions. I have done some research online about it, but I still have some questions about doing the conversion.
I already have the TBI heads on my 86, so I don't think the bolt on will be an issue. I have all the accessories off the 1990(power steering pump, a/c compressor, alternator, water pump, clutch and fan, water pump pulley and balancer pulley), except for the smog pump, and I got to have it in AZ. My question is, can I use the smog pump that's currently on my 86? will it work? I also already have a CS-130 alternator in my truck with the wiring adaptor, Will I be able to use it? I'm sure Ill have more questions for you guys as I get started on this conversion, so any help and advice will be greatly appreciated.
