Turn signal switch
hatch87
tn
Jackson
HELP!! installed a new signal switch today (before nothing would happen when you turned the switch) the hazards worked before I installed it. Now the haszards don’t work at all they don’t click and only make the front signal light come on
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Is the harmonica connector plugged all the way together? If so, still have the old switch?
It can be plugged in to the connector under the column without being reinstalled in the column. If your hazards start working then I would say the new switch is also bad.
Is the turn signal relay bad ? You can use the one for the hazards to test since they are the same and that one was working.
When I bought a new turn signal switch the wiring connector on the end had "almost" the right spacing. However, I couldn't get all the wires to line up and make a good connection, so I cut the end off the old switch and spliced it on the new switch.
Girth
Olympia WA
Garth
V2500 Suburban
Hopefully you didn't put the wheel back on already, that's frustrating.
Had a similar issue with my CJ5. (Saginaw column, fun mix of GM parts in there, the turn signal switch included) Granted, it sounds like you could possibly have some wiring issues, having spiced it? Anyways..... there was a depth difference on the "pads", where the mounting screws hold the switch down. Tightening one screw too much tweaked the new switch, causing an internal short. Really oddball issue that threw me for a loop until I figured it out.
Girth
Olympia WA
Garth
V2500 Suburban
Thinking about it, double check your brake switch. Same filaments used for hazards I think? An issue there could cause problems too.
I’d start with the plug on that turn signal switch though, verifying you got it wired right. Maybe someone has a pinout/wiring diagram handy?
Jgonick
West Texas
Joel
Like @Goldie Driver said- check the connection first.
Also need to ask- Is changing turn signal switch the only thing you did or did you also do something else like changing bulbs? (Incandescent bulbs or LEDs)
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Same. But I depinned my old and new connectors, swapped the old onto the new :slap:
Jgonick
West Texas
Joel
i actually do this and tape the wire ends (pins) together with a string to feed it down the steering column when replacing the turn signal switch. So much easier feeding it down the column without the connector on it.
Blazah
