1988 Camaro
That is a 1988 and is either throttle body or TPI. All Camaro engines were fuel injected in '88.
In '85 there were fuel injected Z28s but the lower level Camaro 305s were carbureted.
Yep, TPI was only available on Iroc/Z28 though. With the exception of the B4C police package for the RS.
However, this one was very very recently (like, 18 miles ago) swapped to an Edelbrock carb. The first order of business is properly running the fuel lines and vacuum hoses.
Sweet project!! My neighbor has a 92 anniversary edition with same looking spoiler. I figured being last year and an anniversary edition it got all the goodies put on it. Front sway bar fat like what you would find on a truck!
'91-'92 Z28 got a similar looking spoiler, but it was much much taller.
Anyone ever see an early F car with the iron duke 2.5? Thats a rare one..
Yep, a buddy had one in high school.
Can still get those wiper blades! Lol. Goofy 80s stuff
The PO put 22" or 24" blades on this one. The passenger side hangs way over, but the driver side actually works fantastic.
80s camaros are potentially equipped with hot fuel supplemental electric fuel pumps to reduce vapor lock (TSB kit , was a common issue apparently)
I wonder if that one has it
That was on the early cars, particularly the L69 HO 305. I've owned a couple of those cars and neither of them had the electric fuel pumps.
This car though, being an '88 and was fuel injected, had an in-tank pump just like every other fuel injected F-body.
My '87 had an electric fuel pump on it. I just remember it being blue and mounted on the frame rail just below the tank in the back. I couldn't tell ya if it was a TSB/GM thing or an aftermarket now though
WFO
Texas Panhandle
I remember ,back in the 80s, seeing the colored 2 blade wipers that also had spoilers or wings on them.
I reckon they were supposed to push them tighter to the windshield at speed.
Probably most of them were bought just because someone thought they were cool, or just monkey see, monkey do.
Sad Sack
Omaha, NE
Goober
C15
Well, if two blades can work on a razor why not a windshield...:shakehead:
filipinochris
