1988 350 TBI Exhaust Manifold Replacement
Vetal4
New Mexico
Ian
V30 Crew Cab
I have a big honking crack under the heat shield on my passenger side manifold.....it had two welds in it when I bought the truck and I've since bubble-gum'd another that formed a couple months ago with JB extreme temp. I think she's toast. Don't really want to put the effort of cast iron welding it or brazing it if its just gonna crack again. So I have some questions:
-Has anybody bought one of the Droman replacements? Chinesium eBay replacements? I can find used driver side manifolds on eBay...but no passenger side...very telling.
-Does anyone have a good used one they would be willing to sell?
-Is there anything better out there (e.i. older, non TBI) that is a direct bolt in replacement? At this point I'd be willing to remove the A.I.R. system.
-Other thoughts?
Thanks!
SquareRoot
Hooker 8525. Love em.
fast 99
Spokane, Washington
Bought an aftermarket L side was horrible, bad threads for AIR, poor casting. Ended up sending it back. You will be better off with a used OEM replacement or those manifolds above if they make a correct set. Removing the air pump may cause other issues, don't recommend that, especially if it's O2 equipped.
Vetal4
New Mexico
Ian
V30 Crew Cab
Those look nice, I'll check it out.
I had a feeling someone would say that....they're just a little too cheap. I've been reading up on the A.I.R. system, supposedly its mainly active during warmup when the system is open loop...I don't really have a problem with the concept, but that thing irritates me to no end. I'll study up on it a little more and figure out if it will have negative effects to remove it.
@AyWoSch Motors Ayden can you help this fellow out with a manifold?
I should have though of that, he's in the same state as me after all....
fast 99
Spokane, Washington
AIR pump injects into exhaust during warm up to preheat O2 sensor and cat. Would assume with O2 in open loop longer fuel millage might be less and cat may have issues later on by not lighting off quick enough. May also turn on SES light.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
-Other thoughts?
Thanks!
Yes, yes i do. I have about 10 whole sets of manifolds. Let me know the exact shape/style you want and ill get you one.
I can get a matched set too if you want.
you can have it, just cover shipping, i have so many, id love to get rid of them.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
I have a few, haha.
Take your pick.
Vetal4
New Mexico
Ian
V30 Crew Cab
I have a few, haha.
Take your pick.
Wow. That's fantastic! Thank you and thanks @idahovette for thinking about contacting you. 3rd from the bottom (with the big N cast into it) is the closest one to what I have...3rd from top (also with big N) looks like the other side...I'll send you a PM to arrange....
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
@Vetal4
Heres the broken stud i was talking about...
Vetal4
New Mexico
Ian
V30 Crew Cab
@Vetal4
Hey sorry I didn’t see that last post for some reason…but yeah, shouldn’t be a problem for me to extract…
dannyphx
