1987 Silverado Help!
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
ok should i use carb cleaner to clean the throttle body it is sorta dirty
Yeah, but grab another can just incase....good to keep extra around, especially when tracking down problems. Grab a plastic bristle solvent brush too, will keep you from using so much carb cleaner. Wear gloves, and safety glasses....dont want to get a ricochet spray in the eyeballs.
Swims350
Logan WV
none
I don't care if they need it or not I'd change them. I had tons of issues with mine and changed them all and so glad I did.
no clue on sizes gotta take them with you, only need one of each and I think there is only 2 maybe 3 sizes.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
And get a plastic scraper to scrape off any stuck on gasket, not metallic. I'll get those pics to you.
Jims86
Patterson,Ca
5.7 TBI
But, He is learning now, and should do only one thing at a time, then test to see the effects. All he has to do is take the old lines to the store and match them up.
Swims350
Logan WV
none
yea he's learning but if he changes all the vac. lines now, doing them one at a time, take one off cut the new to length, then put it on, remove another and so on.
Then once done you'll have them all changed and can see how the results went.
Jims86
Patterson,Ca
5.7 TBI
Yep.
Swims350
Logan WV
none
I just wished I had pics from when I tore mine down. it had all the factory crap, I just never got any detailed pics.
AMW
Adrian
R10 Silverado
well i changed the hoses what hoses i could find to replace that is and i replaced the gasket to the throttle body tried to start motor lol out of gas fighures so i gotta wait till i can get some gas to test this all out getting the throttle body off was easy putting it back on was pain the two fuel lines were tough to get screwed back on but i got em, back to the hoses i just replaced what hoses i seen vaccum or not i replaced them still got to get some more hoses for few i didnt have right size.
AMW
Adrian
R10 Silverado
i also cleaned the throttle body pretty well with the carb cleaner lot of black liquid ran from it lol, im still worried about the two hoses plastic hard hoses that come of that plug with the etc wire tan and black wire those two hoses go nowhere that i can see?
Jims86
Patterson,Ca
5.7 TBI
Those two wires go to the egr solenoid, which you may need. may be best to go to the wrecker and grab one with the plug. Does your check engine light come on?
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
Hopefully these pics will help you.
Jims86
Patterson,Ca
5.7 TBI
There is so little on the TBI engines anyways. The only differences I have seen, are some have smog pumps, some dont.
Until the 96 TBI Vortec, the differences were minimal between 87 and 95.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
A few more.......
AMW
Adrian
R10 Silverado
Well i got gas today put 3 gallons in and for some reason the truck tries to start it spins but its getting no gas i can start it by pouring gas in throttle body but it will only run till burns the gas out for some reason it isnt sucking gas from either of the tanks i unplugged the hoses to see if it would start still wouldnt checked for wires i might had unhooked and couldnt find none.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Check your fuel filter(s), then your fuel pump.
BrickBlazer
