- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
GM is the correct answer - They made 3 types for different uses.Couldn’t answer question on brand. It was just a whatever was available so I could get the truck home since it was in a different city. I assume standard motor parts or something similar. It was from oreillys and a pain to change. I do not think it has a solenoid but I couldn’t answer that without looking at it and looking for a solenoid. Off memory I believe all there is a vacuum line going to map maybe? Or somewhere similar.
19250342 is also 214-2294 which is a new vacuum operated PURGE VALVE for evap. if yours looks like that PN, a new one is probably wise
does this appear like your components? this should cover 87, but Just checking with you.
Also that check valve for the manifold vac is going to be important to be working too. if your engine lowers vacuum and it doesnt check valve, thats gonna **** up your MAP reading because you have a vac reservoir, dash AC and cruise control thats not supposed to be at play here. MAP readings being off will cause you issues easy.
this is the solenoid. gm makes two, one is for leaded gas so you dont have much to accidently mix up if that is old/needs replacing.
SO WHERE WE ARE AT NOW: you should check out that solenoid for sure, but you dont know if you have the right one and sorry but those cheapie dollar store ones especially since you didnt walk in there with a part number for what exactly that truck has, you probably have something incorrect or just not working. Do you have your original? We can ID that if has numbers or by the seat.Finally found some great info for GM EGR identification in the book for my vacuum gun kit!
You must be registered for see images attachYou must be registered for see images attachYou must be registered for see images attachYou must be registered for see images attach
so asking for a friend but your comment "all there is a vacuum line going to the MAP maybe"
You have nothing else conencted to TBI vacuum ports?
and simple diagnostic on your problem at hand, vacuum port all 3 spots that vacuum isput. The TBI, the EGR, leave it connected to that solenoid, and cap the solenoid feed from the TBI. Vacuum caps are cheap. and unplug the solenoid when you do this. That will make the computer NOT ever adjust AFR around assuming its part of the system since it wont have anything to command, it wont try and do so.
