mcarlo86
- May 17, 2019
- ND
- Brian
- Suburban
The brakes on my motorhome have gotten quite sketchy so I decided to look into it since it is in the shop and it is too cold to do much of anything outside. I opened up the master cylinder and found that the rear section for the rear brakes is basically empty.
I went looking for the leak and see that there appears to be fluid leaking from between the master cylinder and the hydroboost. I’m not sure if it is brake fluid or power steering fluid as it is kind of a red/brown color. The power steering reservoir is low on fluid. I don’t see any evidence of leaks at the power steering pump or steering box. The fittings for the lines going in and out of the hydroboost are also dry. I have not pulled the rear drums off yet, but there isn’t any evidence of brake fluid loss on the back side of the drums or along the brake lines anywhere.
I do think I will replace the master cylinder and was wanting to replace the hydroboost unit also, but it looks like the hydroboost units are out of stock everywhere. Can those hydroboosts be rebuilt?
