73c20jim
- Jun 11, 2018
- Tombstone, AZ
- Jim
- C20 2WD Custom Deluxe. C10 2WD Base Model
- 350 CID 195/260 HP Goodwrench crate, 400 CID 2bbl
Just bought a 1973. Thought I did good but have purchased a money pit. Just about everything is bad.
I have completely disassembled the non-tilt steering column and have it removed from the car. I have removed the upper and lower races frm the upper bearing ( the one in the ignition key housing). Both inners are still in the column. I have cleaned both outer races and they look good. Can't get to both inner races. I can see how the bearing is listed with the housing, which is no longer available.
QUESTION #1
Can I get a new bearing for this housing. My research shows PN# 5674684 discontinued, replaced by PN# 7817365, also discontinued replaced by 7800269, also discontinued. Are these the right part numbers for this housing bearing? If so I can get it on eBay.
QUESTION #2
If this is the correct bearing, how do I remove the inner races still in the housing?
Thanks in advance for your help.
QUESTION #1
QUESTION #2
