1965 Chevrolet C-10 build
1low4x4
Nick
Thanks dudes. The engine mods are up for discussion anyway..I figure tuesday I will tear it down and at least have the block looked at and cleaned by my machine shop guy.
Heres a pic of mytoddler helping out today...Shes finally old enough that I can bring her out with me while I fool around. Just have to watch her close cause she'll make a bee line for the garage door opening lol.
Cool picture man :D I love when my little guys are out there taking interest in what I'm doing. I just have to be careful they don't throw stuff in the direction of the truck :lol:
Ahaha, she waxing daddy's truck?
CknightK10
California
Probably my favorite body-style fleetside... Badass...
CknightK10
California
I think you should build a 327 and do this
dont touch the paint :)
I'd agree, best fleetside body, but not lower it then rock it.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
I like the idea of the blacked out rallys! Ever thought about painting it red so you can show it next to the '85? My buddy did one of these in the metallic hunter green with white top. It was tight! If you won't want it to sparkle too much though, you could always go with a dk green single stage & white top. Then green rallys, trimmed in chrome with white walls. I think that would look sick!
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
BTW, awsome find on this truck. A guy I work with is starting on a '63 w/a 283 in it. It was even worse than the one in Iman99's pic, but it had a 283 that got running with very little cost. The think has a plywood bed and the body is 70% surface rust, 20% cancer, and 10% good metal. For $900, you got a deal!!!
1low4x4
Nick
If the paint was original and didn't have a ton of poorly done bondo under the doors I'd leave it.
Also, out of curiosity, what's so special about a 327?keep hearing that.
1low4x4
Nick
If I was looking for that kind if power I'd swap in an LS drivetrain. They can be found much easier than a 327
327 fits the time period. It was the hot small block when that truck was new. It responds well to HP parts, like a 350... just slightly less low end but likes to wind out a little more.
So what's special about a 327 ??? All depends who you talk to. As bucket say, it does fit that time period. However, some don't kmow the difference between 327's, Thru 67 the 327 is a small journal crank just like the 283. In 68 and 69 the 327 went to large journal which is the same as the 350, hence 68-69 327 blocks are the exact same block as the 350. They are identical blocks and in those years, even share the same cast #'s. So if you get an engine with the 68 or 69 350 cast #, it could actually be a 327 and vice versa. The advantages and if you want to run the 327, you'll want the small journal 327 since its not only year model corret for your truck, but both small journal engines, 283 and 327 are forged cranks. All of them, not half of them, or only truck models, or engies in front of manual transmissions, but all of them. Many think the smaller journal is weaker cuz its smaller. NOT TRUE. The small journal 327 is turning a smaller mass. If you took a large and small journal 327 in exact same set ups as far as cams, heads, car etc, the small journal would win a 1/4 mile race. Only 2 reasons and it wouldn't be by much, but just enough to make a difference. #1, less parastic hp loss to turn the rotating assembly with less friction drag of having smaller bearing surface. #2, the small journal will get the rpm up quicker and the small journal will turn a higher rpm too. Even in a 2 bolt main block since small journal was only available in 2 bolt. Again, smaller journal, mean less strain on the main caps, and the forged crank is not likely to flex either.
Ok so with all that..... Good Luck finding a small journal 327 and if you do, be prepared to pay big bucks for it. Honeselty, you can probably find a 5.3 LS engine for cheaper than you can find a SJ 327. The last 327SJ long block I seen on CL, the guy was nuts and wanted $1000. I love the old shcool idea with that truck, but you mentioned it yourself, I'd love the LS new school in the old body style too. Realistically the cheapest fatest way to get the truck running, and cloest to old shcool you can reasonably get, is to go with the older 2 peice rear main 350. They are plentifiul, the rebuild kits are cheap and they are easy to acquire parts for quickly. If that truck has the rear end I thnk it does, it probably has a 3.90 gear ratio in the rear end, so an old school 350 with a 700r4 would be a great choice and probably get a litle better mpg than your Squarebody.
codyc1350
