K10eddie
- May 27, 2018
- Connecticut
- Ed
- K10
Hey guys,
So I'm going to be going through almost my whole truck for a moderate restoration, and I'll be rebuilding the front and rear differentials as part of that. The truck is a 1979 K10, currently it has a 383 making 450hp, and i might swap it to a big block with similar power, or just put a turbo on the 383. So far I have the following list,
Rear
-Timken bearing and seal kit
-Moser cover
-Moser axles (?)
-True trac carrier (?)
-Reusing 3.08 gears as long as they are good (TH350 at the moment, I want to get what little fuel economy I can)
I'm unsure if the axles will be necessary, and the true trac sounds like a good move, but I'm unsure if it can use synthetic oil. I'd rather use synthetic with a limited slip, because I might move back to Wyoming for work, and it gets cold up there.
Front
Most likely just going to use a timken rebuild kit, I'm unsure if having a locker or limited slip is worth it for me. I might get a cover for it.
If anyone has any suggestions, I'm open to them. Thanks!
Rear
-Moser cover
-Moser axles (?)
Front
