Computerized carb
iservin619
san diego ca
Ivan
GMC sierra
350 small block
Can you put a non-computerized carb on a truck that originally had a computerized carb??
Edelbrock
Senior Member
Earth
Grumba
K5 Blazer
Whats a computerized carb? Do you mean throttle body fuel injection?
Technically yes, you can put a carb on any engine. You could put a carburetor on a diesel engine. It just depends on how many mods you want to do.
fast 99
Spokane, Washington
Feedback carburetor with internal MC solenoid. Think they were only used one or 2 years on trucks. Cars were quite a bit earlier. Actually a decent unit but takes a couple inexpensive tools to set up properly.
Do you truly have a computerized carb or a dual accelerator shot carb? If you have a throttle position sensor on the drivers side and a 2 wire solenoid on the front passenger side top it is a computer controlled carb,if it just has the solenoid top passenger side it is a dual accelerator pump shot. I doubt you have a ccc carb, 1 year only, California only, to the best of my memory. The dual accelerator pump carb is the same as any other quadrajet if it is disconnected.It will cause no issues. Switching to a different quadrajet may cause issues,they are not all set up the same. Different jets,metering rods,air bleeds,spring windup,etc. If it is truly a ccc quadrajet,post back letting us know. Using a non ccc carb on place has its complications,we'll need to walk through the mods.
1983 manual
Cars did have it yes
Yes but trucks it was a 1 year only,California only deal as I remember it.
Fat 454
Australia
C20 Suburban
"Computer Command Control" - producing "harmless CO2".. wow, I wonder how many GM executives today remember this ad ?? Priceless !
iservin619
san diego ca
Ivan
GMC sierra
350 small block
What exactly are these in expensive tools I have a dwell meter on the way should get it this week but besides that I don’t know what else there is to get it dialed in.
iservin619
san diego ca
Ivan
GMC sierra
350 small block
I sent my carb number to mountain man and he stated that it came back to a computerized carb. Which makes sense since it was originally sold in California. I was asking because I just tried to turn it on yesterday and it cranks good but it doesn’t seem to get gas. When I first turned it on after buying a new carb from national carbs it ran ok not super well but ok. Drive it around a couple times seemed good but under load I could hear it backfire pretty bad from the carb. Took it back home shut it off figured I had to dial it in once I got a dwell meter and now it won’t turn on. I’m sick of the headache and since I’m so new to all this distributor, timing, mixture screws I want something simple and easy. My dad has an older 77 gmc and that thing runs super nice doesn’t bog out when you get on the gas always fires up after a little pumping of the gas and has never had issues. Any recommendations on what I should do? I know being in California and having to pass smog will always be a headache but I have someone that can take care of it passing smog if you guys know what I mean so I would be willing to remove all that catalytic converter stuff this truck has.
iservin619
san diego ca
Ivan
GMC sierra
350 small block
1983 manual
This is indeed right the truck has a ccc carb which I have now come to realize how big of a headache that thing is.
So you have a new carb from national? What engine did you buy the carb for? I'm pretty sure the ECM on that truckn8s going to need to see a throttle position signal to control timing. Look at your Distributor,no vacuum advance can will confirm this. Have you run compression on this engine? If you don't have good compression on all 8,anything you do to it is pointless. Post back what carb you bought.
fast 99
Spokane, Washington
iservin619
san diego ca
Ivan
GMC sierra
350 small block
I bought a new carburetor from national confirmed with the staff from national and they said the one I was looking at was in fact the one I needed I’ll attach a picture of the one I purchased. Installed turned it on and ran fine. Now 2 weeks later it’ll crank but won’t fire up opened up the choke flap to see if there was any gas but nothing. I have never ran a compression test on the engine I’m not too sure how you do that. As far as the distributor do I check for vacuum or what exactly do you mean? I’m super new to this so my apologies on million questions.
F1r3truck
