Tq converter for 5.3 ls swap in a 700r4
tjw82c10
Los Lunas, NM, USA
Tyler
I am in the process of putting a 5.3 in my 82 c10 and am just planning ahead. Im keeping the 700r4 and just gonna get it rebuild and put a slight shift kit in it. This is going to be a long distance truck for fishing / camping trips. I dont know much about what the stall means and I was curious for what kind of converter / rear end gear ratio you are running for a good medium between mpg and acceleration. Im thinking of doing 3.73 in the rear cause what I have read that is a good medium but was curious about the converter still. Thank you in advance.
If you can get one, it will be faster and easier to just get a full 5.3/4l60 combo from the donor. A 4L60 is identical to your existing 700R4 externally, but you won't have to worry about a TV cable and you can adjust your shift points and pressures from the computer at the same time you are tuning your engine. 3.73 or 3.55 would be a great cruising ratio while still giving you some low end grunt.
tjw82c10
Los Lunas, NM, USA
Tyler
Well the whole reason im wanting to keep the 700r4 is due to it just being easier to work with (to an extent) and to eliminate alot of the wiring, im fine with the tv cable adjustment its not that big of an issue. I was thinking of keeping just the stock converter but thought id dip my toes in the water and see what your guys thoughts were. Also side note I just got a call back from the trans shop about rebuilding it for 400 hsp which its mainly just for a cushion, they are asking between 2500-3500 depending on parts so i think imma just go buy a new one cause its practically the same price on summit. What aftermarket transmission companies should i stay away from?
Nobody sells a new anything. If you buy one from summit it is going to be rebuilt. I'd take the one rebuilt by a reputable local company over a mail order trans every day of the week.
The factory 4l60e that is going to come with your swap engine is already "built" for the power and would likely last many years just as you got it. All of the "built" parts that the rebuild shop would be putting in are the improved parts that are stock in a 4L60e because they have found all of the weak points over the last decades. There is only ~6 wires going to the 4L60 from the PCM... its way simpler to just use the stock PCM, stock engine/trans, stock converter, stock wiring harness, etc... than it is to try to find a way to properly control that TV cable from the LS throttle body, dial it in right, and try to beef up and rebuild that junky 700R4.
If I were looking for a performance upgrade,on a factory converter,I'd use this chart. The factory converters have a 4 digit code 1st digit is transmission type,second digit is stall speed. I don't remember the second 2 because they weren't important to me. First digit D 700r4/4l60 2nd digit is stall speed so a DB?? Would be 700r4 2025 stall speed. DBLF is a 1995 S10 700r4 2025 stall speed so still a reasonable choice for a daily driver by GM standards. Do not use parts store parts book torque converters by application,unless they can verify stall speed. They consolidate the applications,so they can reduce costs, you may order a converter for an S10 that factory was 2025 but may get a converter for an Impala with a1397 stall speed. Because most car owners will not notice the difference.
This. OP, I know you don't want to hear it but the 4L60 really is the way to go. Guys online fight doing the 4L60 all the time when in reality, it's far harder to keep the 700R4 and make the TV cable operate correctly (there's no truly good way to get it to work with a throttle body). You already have to buy a harness, so just get one that has the control capability for the 4L60 built in and you're good to go. Just make sure to grab the TCM out of the donor as well.
As for the torque converter, that depends on what you're doing to the motor. Keeping it bone stock? Keep the stock converter. Stock in an NBS truck (99-07) is something like 1400 stall speed (stall speed is where the truck actually begins to move once the revs come up). That with a 3.73 rear gear will cruise like a stock truck and still have a little pep when you step on it. If you're gonna slip a cam in it, then you need to match your converter to the cam choice.
Here's a good video of how a torque converter works:
For example, when I first built my truck I grabbed an LH6 5.3 out of an '06 GMC Envoy Denali and slipped a BTR Stage 4 V2 truck cam in it for some chop and performance gains. I decided a Circle D 2800-3000 stall would be about right. I also wanted a little more oomph than my friends with 3.73s so I went 3.90 gears. That was a PERFECT combo. Put 27.5k miles on it before I swapped in a stick shift and never wanted for more or less gear or cam. It cruised at 2250 at 70mph and got 18-22mpg on the highway. The stall converter honestly could've been a touch looser, it would surge at stop lights if I didn't have my foot on the brake enough (with that particular cam, with a milder cam it would not have done that). In hindsight I would go with a 3400-3600 stall with that cam.
tjw82c10
Los Lunas, NM, USA
Tyler
I guess i should also mention that the LS is gonna be carb.... to me it makes sense to keep the 700 at least until i can get like a 6l80e which is waaaaaay down the line of things and then do the electronic one. I guess I could always just get a reman 4l60e which i work for a shop so i get a slight discount and spend the extra money on a stand alone. Good
Yeah i think im gonna just go with the 4l60e. Was looking at ete and its slightly cheaper to just get a reman with my discount than to rebuild the 700r4 plus an aditional 600 for the stand alone. Also my set up is for a carb. im gonna keep the 700r4 for now until i can get 3k for a trans lol. Now i gotta worry about getting the damn thing in first. Any recommendations for motor mounts and the 700r4 to start?
Wait, why go LS and convert to carb? You'll have more money tied up in the carb conversion than you will to just keep the fuel injection.
For mounts, Tejas Steelworks are the best and easiest around. Got them in my truck and they're awesome. Motor mounts, trans mounts and fan shroud for dual 13" Spal electric fans.
NickTransmissions
Las Vegas
Nick
Be very wary of reman transmissions by large companies that spend all their money on advertising/marketing. Ive torn apart hundreds of them over the year, lots of corners are cut. Rebuild your 700R4 properly. The $2500-$3000 you were quoted is consistent with what Id charge for one built to handle up to 450hp in a street/strip application. Find out what parts are included. 2200-2500 converter stall is a nice balance between performance and streetability/reliability for a Gen3 small block, either bone stock or a small cam.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I agree. Seems counter productive to upgrade to a modern engine and give it a lobotomy with a carb. Especially considering how expensive those ignition computers can be, they aren’t much cheaper than a pcm to do everything.
It's like all the guys on FB that want to keep their TH350 with an LS swap, you're negating half the benefits not going to an overdrive
bruisedbanana79
San Diego, CA
Jeff
Suburban
Not wanting to beat up your build plan but I also agree with the rest. Spending $3K on an older trans is not worth the money. I did the 5.3/4l603 swap on my K20 suburban which is much heavier than your truck. I am running 3.73 and 33" tires with the stock motor, no cats, all smog stuff removed and the truck pulls onto a freeway faster than my 02 suburban. If you plan to build it grab a 4l80E and it will handle some extra abuse. I know nobody will believe me but my whole ls swap only cost me $2K out of pocket and is the best low buck swap I have ever done.
tjw82c10
Los Lunas, NM, USA
Tyler
For mounts, Tejas Steelworks are the best and easiest around. Got them in my truck and they're awesome. Motor mounts, trans mounts and fan shroud for dual 13" Spal electric fansI
I got just a short block and without heads or a wiring harness, and i did price everything out its about 1500 bucks less just to do the carb and its alot simpler for me so its a better option.
tjw82c10
Los Lunas, NM, USA
Tyler
Got it as a short block so id have to buy pretty much new everything and its 1500 cheaper to just make it carb, plus less wiring. I know everyone is gonna be all "wiring is that hard", yeah for the people that have been doing it forever its easy. Besides the ultimate plan is to get it running first, keep the 700r4 for a bit, swap in a 4l60e with a standalone, get it looking the way i want, and then convert it over to fuel injection again but with a carb style intake which look pretty cool in my opinon so well see. Gotta get more experience before i tackle that.
tjw82c10
Los Lunas, NM, USA
Tyler
Im doing it in stages, im on a budget so trying to save as much as i can then go to better stuff.
GorillaHumper
