Sgt Gus
- Aug 2, 2023
- Texas
- Mark
- R20 3/4 ton
- 454ci/7.4L
On our 87 silverado (two 20's) the senders are pretty much between the cab and bed. So far, pulled down and fixed drivers. Whew doggies!I'm just getting caught back up here on the gas tank discussion. Are you saying your senders are under the bed? Every shortbed 16 gallon tank I've ever seen has the sender under the cab like soundmound's truck. Mine are that way as well. Only the longbed trucks got had the sender under the bed (20 gal tank, not sure where it landed on longbeds optioned with the 16gal tank/tanks)
