Fuel Gauge Tank Selector switch and valve
danzey
Kansas
Danzey
1984 K10 - two new tanks. Two new fuel sending units. One is an ac delco the other is from LMC. Ground from battery to frame and then to sending unit is good.
Fuel gauge is stuck at 9:00.
Fuel selector valve moves between the two tanks but doesn’t run correct on the passenger side as it will only idle and drive around slow - any throttle demand and it dies. Assuming I should replace selector switch first and then possibly the selector valve?
Can the switch and or valve cause my fuel gauge issue? The pink/black stripe wire is not carrying any resistance up to the gauge.
Jgonick
West Texas
Joel
Fuel gauge at 9 all the time or only with passenger tank?
Usually PNK/BLK goes to valve (from passenger tank sender) and from valve the PNK goes to gauge.
edited to include wiring diagram-just in case.
danzey
Kansas
Danzey
Thanks. Yea I meant all pink. The fuel gauge is at 9:00 all the time with either tank selected.
I feel like the sending wires in the tank valve are not connecting to the pink wire. Can you pull the plug and jump a green wire from tank sending unit to the pink wire running up to the dash to see?
grummy
Midwest
C1500
Not the Switch I dont think, but the valve... Yes. The Valve has the contacts in it for the sender selection. I did two new tanks as well, and I thought I was out of luck getting the gauge to work. But, I switched the tank valve back and forth a dozen times, listening for the moto in the valve to run. And, my gauges started working ! I think the contacts in the valve were dirty and moving them in and out, they must have cleaned up. Now I switch between tanks every fill up to keep things moving.
If they were not going to clean up, I probably would have run the two tank sender wires up front and put in a temporary switch that would feed the pink wire until I could save up for a new valve.
75BEASTK20
B.C. CANADA
Cal
I had nothing but problems when I first got my K20 dual tank.
Bad wiring was first- wires everywhere. Bad ground. Finally said to hell with it and did two new tanks, two new sending units and all new wiring. Kaching$. but she works now
Jgonick
West Texas
Joel
PNK/BLK or PNK/WHT (depending which tank you are checking) could be jumped directly to the PNK wire.
The sender controls the current going to ground. The more current going to ground the more the gauge heads towards “Empty”. Unplugging the PNK wire completely should send the gauge past full (3 o’clock)
Here is a good video explaining how to diagnose a gauge
LINK - fuel gauge diagnose
Dmack
Central OR
Dave
Gauge stuck at 9 o'clock means you have an open circuit, so something isn't connected/broken wire/etc.
I fought mine for a while before finding it was a bad dash selector switch.
danzey
Kansas
Danzey
I jumped the two tank wires over to the pink one at a time and the gauge read full (both tanks are full)
So the sending units have ground and are working. I’m going to put a new switch and tank valve in and hopefully that fixes the problem.
danzey
Kansas
Danzey
I ended up putting in a new switch just to eliminate that possibility. I chose to put in a 1987 switch that isn’t momentary. I also installed a new fuel valve and bingo the problem is fixed. Now the biggest challenge will be how to get the heat shield back in place to protect the new valve from the exhaust heat.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Sounds like alot of work. I have to dig into passenger, aux tank and figure out why that side causes it to die. I was thinking fuel pump, but guess I should ck voltage of wires at valve 1st. Not looking forward to it.
Good job.
danzey
Kansas
Danzey
I just replaced the valve and switch for my 86 k10. Both tanks new and new sending units. All is now working perfect.
The problem - after replacing the valve I have a slight hesitation at 1600 rpm that wasn’t there before. I have a new fuel filter in place.
Any help would be appreciated.
Dukester68
Gary
c2500
Hi! Ive been following as i have same issue. New senders which i tested the ohms before i installed. Now installed and testing with ground or plug disconnect doing what they should do at the gauge but my drivers side will not go above a quarter and it is full and… getting 87 ohms. Pass side almost empty and reading 32, both directly at the senders. Could this be in the fuel valve? Thx
grummy
Midwest
C1500
Do you get the 87 Ohms directly at the sending unit itself ? If so, check what it is at the wire right where it goes thru the firewall. If it is not the same 87 ohm's or thereabouts, then yes, I think the contacts in the valve could have corrosion on them that increases the resistance, even though it still makes some contact. Both sender wires go to the valve first, and that is where they are switched to send to the single wire running forward.
Dukester68
Gary
c2500
Yes at the sender. I thought i would go to the plug and measure it there but good idea
grummy
Midwest
C1500
If your Ohms are different at the firewall, then crawl under the truck and pull the plug on the valve and check them there. Maybe you just have corrosion outside the valve itself... in the plug connections.
If I ever had to change my valve out, I would knock the original apart just so I could see what the contacts look like in there.
Lancew
