87 Half ton crew cab
Terry Wilkerson
Kansas
Terry
GMC 1500
Welcome from KC
You obviously are a sticktoo kind of guy. Nice work.
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
Love this truck, beautiful work y'all have done! Looks like it left Detroit like that!(Or Flint GM Truck and Bus plant, where the "factory" Crew Cabs are built/modified).
Dad always wanted a square body Crew Cab, but we had 5 square body Burbs. Now I have an OBS Crew Cab.
SQ HAF KRU
Surprise, AZ
Greg
1/2 Ton Crew Cab
Gen V LS 5.3
What material did you use to lengthen the 1/2 ton
frame with? The 1t is taller, correct?
We used the same thickness as the original frame rail, welded that into place then added an over wrap of steel with large circles to do flood welds, and it over lapped the 1st weld.
Bennyt
Surprise
Ben
Really cool, thanks for posting !
I actually saw it in person a few months back when I was leaving Home Depot in Surprise. You were driving through and I thought I recognized it. Great Job!
arm019
