lessersivad
- Dec 24, 2015
- Morenci, MI
- Russ
- 1977, 1979, 1982, (2)1985 1985
- C10, K20, K10, K5, K2500
- 250,305,350, 6.2
I like it!!!
What material did you use to lengthen the 1/2 ton frame with? The 1t is taller, correct?
We used the same thickness as the original frame rail, welded that into place then added an over wrap of steel with large circles to do flood welds, and it over lapped the 1st weld.What material did you use to lengthen the 1/2 tonYou must be registered for see images attachYou must be registered for see images attachframe with? The 1t is taller, correct?
Really cool, thanks for posting !We used the same thickness as the original frame rail, welded that into place then added an over wrap of steel with large circles to do flood welds, and it over lapped the 1st weld.
