CARBURETOR DATED
boloboss
Houston Texas
Shuntel
Chevy C10
v8 350 5.7 liz6er
My timing was initially set at 4° and I turned the distributor just a smidge it to advance it
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Seems like theres potential the timing could be retarded too much and its causing your issues with not wanting to start back up after being ran a while
Try 8 or 10° and see if it does it anymore
Vbb199
Salisbury NC
Vince
That might necessitate enrichening your idle mix a little also, but perhaps not
ali_c20
Austria
Alexander
C20, K5
I run 12 degrees on my K5 and 14 on the 66 Impala.
Always be sure your ignition system is working as it should before fiddling with the carb.
Search Uncle Tony's Garage on youtube, this guy knows tons about carbs and ignition and all the other stuff.
He's a Mopar guy but the principles are the same for all engines.
Generalmoto
canada
Josh
I was having this same issue over the HOT summer, initially thought it was because I swapped in a metal cased Wix fuel filter.
Ended up being the ignition module crapping out a few times before finally failing for good.
Next time the issue is happening, check to see if you have spark from the plugs, if not, swap your ignition module
I had weak performance for a year couldn’t figure it out until I pulled a plug and looked at the spark. Was weak and yellow instead of blue and crisp. Changed the coil and big difference.
I agree those ignition issues slowly sneak up on you
SmokinB
Oklahoma
Scott
Silverado K10
What's up guys?
I have a 18 -year-old 1406 Edelbrock carburetor that's been rebuilt twice. Ot stars right up in the morning, no problem......but, I've been having issues with it not cranking right up after I've driven it for 30 minutes, let it sit for while, then try to start it up again... and after that, if I turn it off and start it up again it cranks right up .Do you recommend me buying a new one or rebuilding it again? And if I buy a new one, what carburetor do you recommend? I have a 350 small block in a '84 Chevy C10
I have the same issue. The fuel is getting too hot. Use a carb spacer that will insulate - and block off the crossover directly beneath the carb if possible.
op can you show me your distributor with the cap off like this picture here?
boloboss
Houston Texas
Shuntel
Chevy C10
v8 350 5.7 liz6er
Also, will covering up the crossover on the carburetor intake reduce the overall temperature of my engine
MikeB
North Texas
More than likely, intake manifold heat is causing the gas to evaporate. Try raising the float level above spec for starters. The owners manual tells you how to do it. Also try a phenolic spacer at least 1/2" thick.
I'm having a similar problem with an old 1406, that otherwise works perfectly. Unfortunately I won't be able to continue troubleshooting until the ambient temps get back up into the 90s. I've got my eye on an AVS2, but I'd like to hear from the guys that have one, because the float bowls are still in the same place--way down low close to the manifold. A Holley or one of the clones like QuickFuel or Brawler shouldn't have a problem because of float bowl location. Or at least not as much of a problem.
Sad Sack
Omaha, NE
Bryan
C15
Just a random thought but has anyone considered a drain-back issue?
slammed84
Oklahoma
Nick
lol that dizzy needs help!
It almost looks like the vacuum advance got broke off, JB welded over, and a new fitting re-drilled on top of the canister
Not a possibility on an Edelbrock 1406,due to location of fuel inlet and needle and seat. 2 like these should stop your fuel boiling. If that's the problem
wdym not possible?
83NicK10
