- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
im looking at very little fitting, overall, in my extended cabs short bed if i either set the tailgate down and have them sitting on it , or if i remove my toolbox and use the bed up to the cab,
And one drum will be metal, the rest plastic. I could optimistically fit one inside the cab in the back seat
Two if no passenger
I have rails for a 5th wheel which i think i can exploit to help hold down these things, but they wont be sitting that flat either for the same reason.
Of course, I will need to trailer the rest. I have my truck bed trailer, in fact, its cleaned out the only thing is that the topper is there, which would permit the same height of stack as this photo above, but i would be limited in the very front where its angled up to ramp above a truck cab.
I could also remove it, but to no gain in carrying capacity that I could conceive.
I have my car trailer, flat deck and large, great tires , so not worried there. Would take my magnetic tails because one side is bad somewhere. But whats the best way to bundle them that way? all 1 high, wrap them into a giant grid , and then strap the grid down to the trailer? small stack in the center? weight wont be really much issue here so i wouldnt need to be "centering" over an axle , its not a lot of weight.
I am going to need to get a couple ratchet straps I think to do such large distances , small ones work but the length is at issue I could also use chains
