Brakes
keegansquarebody
michigan
Keegan
R1500
5.0 V8 305
I have been through 4 master cylinders and finally believe I have the correct one. I can get brake fluid consistently to the front and when the bleeder screw is cracked the pedal drops. When I loosen the back the pedal doesn’t drop and air is always in the lines no matter how much we bleed it. There is no brake fluid leaks at all. We took it for a drive to work some air out and the pedal goes to the floor but still works. When we were done driving it the rear brakes were hot so they activated a little but not much. I was thinking it was a pushrod in the vacuum booster to master cylinder but it wasnt. I cant bleed these stupid brakes. I just checked and the parts store gave me a wheel cylinder for 11 by 2 inch brakes when I have 11.25 by 2.75 brakes. Could this be causing all of our problems or what is the problem?
Auburn, Washington
That could be the problem but if you can’t get fluid to the back brakes the proportioning valve is tripped. Just replace it anyways. Old truck.
SquareRoot
You can thank me later. Having the correct parts is on you.
fast 99
Spokane, Washington
Agree with the possible diagnosis. Question replacing the valve unless it has some other obvious issue. Read several posts about new PV's leaking or just plain failing. One failure was on a TV series, leaked. Most of the valves are offshore production.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Yeah keep your original proportioning valve. Or source a good used factory one if it comes to that.
Ken B
indiana
ken
the pv tool that centers the pv while bleeding helps. I went thru 1 new chinese prop valve then spent a little more on a 2nd one and it didnt leak
Oldbear42
Linden, Alberta, Canada
Shaine
C20 LWB Scottsdale
I got to change mine out a week AFTER installing the rad and fan shroud, but the new inner fenders were not installed yet. I didn't know my old body could still bend like that.
Rustisbest
Athens, TN
What brand was the good one? I'm gonna need one soon for rear discs
Rustisbest
Athens, TN
Get NOS,or junkyard Cadillac Seville or Olds Toronoado
Junkyards vehicles around here are in a grown up fields and mudholes sitting on the ground with no wheels. One even has a couple guard donkeys lol. Not worth the hassle anymore.
cornholeeo
usa
corn
my 77 c-20 w13x2.5 rr shoes, has a stock PV that has centering pin that needs to be held in with a clip that i made, to properly bleed the brakes. Bleed all 4 corners pull the clip and your good to go
ali_c20
Austria
Alexander
C20, K5
I had luck with summit brand proportioning valves. Work as expected and no leaks.
EC Metalworks
