keegansquarebody
- Jul 6, 2024
- michigan
- Keegan
- R1500
- 5.0 V8 305
I have been through 4 master cylinders and finally believe I have the correct one. I can get brake fluid consistently to the front and when the bleeder screw is cracked the pedal drops. When I loosen the back the pedal doesn’t drop and air is always in the lines no matter how much we bleed it. There is no brake fluid leaks at all. We took it for a drive to work some air out and the pedal goes to the floor but still works. When we were done driving it the rear brakes were hot so they activated a little but not much. I was thinking it was a pushrod in the vacuum booster to master cylinder but it wasnt. I cant bleed these stupid brakes. I just checked and the parts store gave me a wheel cylinder for 11 by 2 inch brakes when I have 11.25 by 2.75 brakes. Could this be causing all of our problems or what is the problem?
