- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
Am I to understand you need your PS pump to have the stud on the back for it to mount on the bracket which also tensions the belt? As an idea, you could junkyard a much newer saginaw and use an aftermarket bracket which does not need the stud and have OEM quality and have a pump that is much younger and has some of the minor upgrades found over the years. I also advise a magnetic filter inline the return.
