RanchWelder
- Jan 14, 2023
- Earth
- Blazer
- 355ci
Bought a Power-Master 3 years ago because of charging adjust-ability, L/A vs AGM vs Lithium.
Had no idea what was going to be removed from the shelves because of EPA or lack of manufacturing.
PM is rated at 200 amps.
Never thought the idle voltage was a concern, TBH.
Can see how it matters.
Dim lights, having to throttle up to close the rear windows, even using relays on windows and headlamps?
Generating that extra voltage at idle must increase the heat under the hood at idle too?
From what I have read the Lithium is a poor investment and AGM, (although better reviews for the old school red tops that lasted 10 years or more), either one will fail prematurely without the proper "tuning or adjustment" of the alternator output voltage. (Like the PowerMaster offers, 13.8, 14.6, 14.9 and at different trickle rates, etc). Does this alternator adjust for Lead Acid and at least AGM?
Lithium seems to have issues, if not managed and cotrolled properly?
Not sure. Never owned one.
Highly doubt any old school alternator is designed to protect a Lithium cell.
Read they have a BMS (Battery Management System) stabilizer safety disconnect board that freaks out when it breaks loose from the alternator during charging and the alternator diodes can see 100 volts for a millisecond? Smoked alternator does not sound like a goood idea?
Lot's of sailing videos where they lost the alternator at sea because they were charging LifP04 or Lithium and stuff messed up the alternator diodes?
Many sailors recommend to never connect your solar cells to any standard controller and integrate the Alternator, for this reason. Mixing Lead Acid dual battery with an AGM or lithium, without a select-able alternator voltage such as the PowerMaster 200 amp offers, still requires you switch the alternator settings for each different type of cell, or you'll kill the one you're not switched for. Mix and match is a bad thing.
Here's a link to a load manager that protects the diodes in a mixed charging environment and when using different cells such as in a camper or when tied to a solar or wind generation scenario, with or without an alternator in the loop:
https://www.emilyandclarksadventure.com/bbms/buy
I'm looking at the older model that does not have Bluetooth, if my camper requires the better quality LifPo4 batteries, instead of stoopid heavy deep cell golf cart batteries or the deep cells that cost $250 and die every 2 years, with low re-charge life span count.
The LifP04 might require charging if it's overcast for a week and until I can afford solar cells, for the few days we get full sunny days?
It's cloudy here a lot.
Waiting for the cells to recharge everything while living off the grid might be better to protect the battery brain and alternator investing in a $500 charging controller (see the link) vs spending $500 on questionable quality solar cells, as recommended without an alternator and set up as a stand alone solar LifP04 system?
Don't get me wrong, stand alone solar to LiFp04 sounds safe and is used by millions.
Burning fuel to recharge the batteries off the alternator might save the week on quite a few weeks, without a power pole to recharge for miles?
What do you guys think of the
What works for you and your Sailboat, RV or Motor-home?
What do you avoid at all cost? (Brand names, system controllers, bad quality cells... etc?)
What would you like to own to upgrade your system for off-grid battery and charging /controllers?
BankManager™ Gen2? for an off grid multi battery system?
See the above link for the installation and owner's manual...What works for you and your Sailboat, RV or Motor-home?
