Appropriate Aluminum Radiator
sloane
New Carlisle, Ohio
Adam
I am trying to find an aluminum radiator that is a direct fit on my 79 GMC Sierra Grande w/ 350 and manual trans. Does anyone have a Summit or Jegs part # that worked for them. Looks to be about 33”x20 1/2”
Hit up @Nasty-LSX if he hasn't p.m you. I told him about you,he's got some radiators for sale. Act quick one is new in box aluminum like you are looking for
ChuckN
Bellinham, WA
Chad
Square rads usually come in 19” or 21”. Sounds like you’re definitely a 21”, but double check measurement to be sure .
If the one NastyLSX doesn’t work out, I’ve been very happy with my Cold Case. Here is a search on their website for your year. https://www.coldcaseradiators.com/products/fitment/1979-GMC-Truck-any
The side tanks are stamped to look factory. You can paint them black to help it look stock or just leave them aluminum like I did. They come with a sacrificial rod installed too, so if you were to have a bad ground, the electrolysis would eat that instead of the radiator.
Edit- don’t order one with the “1.75” lower hose option- that hose is a unicorn and if it exists anywhere, I couldn’t find it.
Double edit- never mind the measurement, didn’t see the picture initially that you had it out of the truck.
Carb'ed Vortec 350
Check out northern radiator for a copper brass unless you're dead set on going aluminum plastic, or full aluminum. Pricey, but direct fit, just have to trim the shroud a little.
Edit: The shroud has to be trimmed so it doesn't ride on the core, it's a more efficient core, so it's wider than an OEM. CR1599 is what I got for my 1981 C20.
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
sloane
New Carlisle, Ohio
Adam
Thanks for the input. Sorry it took so long to respond. Im new here and thought it would send me an email when people respond. I will check my settings. I just was going with aluminum cause I like the look and figure it was built better than local auto store stuff.
Carb'ed Vortec 350
An all aluminum might be better than a cheap copper brass knock-off, but the aluminum core with plastic tanks are known for not lasting.
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Weather you buy from me or not, cold case are Bad A$$ radiators. I use them on the c10's
and all the F-body builds I do. ZERO plastic. Dont buy crap like frost and all the other cheaper stuff.
Carb'ed Vortec 350
Didn't know about cold case. A nice option, but made in CHN...ugh...
MyTruckIsBetter
C1500
I know you wanted a summit or Jegs part No. but I ordered my aluminum rad from LMC and it has been working great for ~1 year 12K miles. It is worth noting that the radiator has an oil and transmission hookups too!
Below is the part number and such ran me about 300
32-2946Radiator 454
sloane
New Carlisle, Ohio
Adam
Mytruckisbetter I just looked that up. Its only $200. Hmmmm. I like that price. Sometimes you get what you pay for but you said its done well for you.
Scotthilton
